Attachments to Cut
DREMEL® Line & Circle Cutter (678)
Attachments to Cut
Cut perfect holes and straight cuts with your Dremel Multi-Tool
  • Cut or rout clean, crisp circles in your work piece using your Dremel Multi-Tool and the Line and Circle Cutter attachment.
  • The Straight Edge guide allows you to cut or rout straight lines.
  • Have a fully adjustable circle cutter up to 30cm in diameter to use it for a wide range of projects.
See all variations
19.5 GBP
What can you do with it?
Cut perfect circles from 2cm - 30cm in diameter and sharp straight lines with a width of 1cm - 11cm. Easily attach it to your Dremel Multi-Tool and you're ready to go. With the included Multipurpose Cutting Bit (561) you can use this attachment on materials such as wood, drywall and laminate. The depth adjustment and steel construction gives you accuracy and durability.
How to use?
Insert the included Multipurpose Cutting Bit (561) and screw on the Line & Circle Cutter attachment onto your Dremel Multi-Tool. Set your diameter using the markings on the attachment drill a hole into the center of the circle you want to cut out. Slowly plunge the accessory into your material and start cutting the perfect circle. Use the Straight Edge Guide for routing or cutting in a straight lines.
Package contents
Price
26150678JB
1 piece
£19.00*
  • Cut perfect holes and straight cuts with your Dremel Multi-Tool
26150194JA
2 pieces
£10.50*
High Speed Cutter 3,2 mm (194) 2 pieces
  • Medium sized cylindrical shaped head. Shape of e.g. wood.
26150144JA
2 pieces
£16.50*
High Speed Cutter 7,8 mm (144) 2 pieces
  • Carve and remove a lot of material like wood
26150125JA
2 pieces
£13.00*
High Speed Cutter 6,4 mm (125) 2 pieces
  • Largest triangular shaped head. Shape and create V-grooves in e.g. wood.
26150134JA
2 pieces
£16.50*
High Speed Cutter 7,2 mm (134) 2 pieces
26150114JA
2 pieces
£16.00*
High Speed Cutter 7,8 mm (114) 2 pieces
  • Largest ball shaped head. Carve and engrave in e.g. wood
26150561JA
3 pieces
£13.50*
Spiral Cutting Bits Multipurpose (561) 3 pieces
  • For 'free' cutting in softer materials like soft wood, drywall and plastics
26150117JA
2 pieces
£13.50*
High Speed Cutter 6,4 mm (117) 2 pieces
  • Carve and engrave in curved and straigh material like wood
11 cm
Depth
Suitable Dremel devices
Retired Products
Multi-Tools
8710364081899
26150678JB
User Manuals
Dremel attachment 678 Line and Circle Cutter
Delivery details
  • Circle cutter
  • Straight edge guide
  • 1 Multipurpose cutting bit 561
  • Product box length, 9 cm
  • Product box height, 18 cm
  • Product box width, 4 cm
19.5 GBP
