Retired Products
Retired Products
Light on power, heavy on simple wins
  • Easily switch between applications within many DIY projects, whether its sanding, grinding, sharpening, carving, engraving, cleaning or polishing.
  • Take on multiple kinds of creative projects or light duty DIY projects with the 15 accessories included.
  • You’ll be ready for your next DIY-project anytime and any place with the cordless and USB-chargeable Dremel Lite.
72 GBP
The versatility of this kit allows you to sand, grind, sharpen, carve, engrave, clean and polish, with the only change being the accessory. Tackle any kind of light duty home improvement or creative project. The 15 accessories included gives you the freedom to work on multiple materials with multiple applications. You can use the cordless and USB-chargeable Dremel Lite anytime and anywhere, indoors or outdoors. Whether this will be your first Dremel Multi-Tool or an add on to your Dremel collection you can rely on this kit to complete your projects.
Battery voltage
3.6 V
Battery capacity
2.0 Ah
Charging time
2.75 h
Weight
0.270 kg
19.5 cm
Depth
No load speed
8.000 - 25.000 1/min
Battery technology
No load speed (3)
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
Vibration
8710364081400
F0137760JB
User Manuals
Dremel Lite with 15 accessories
Delivery details
  • Dremel Lite
  • 15 high quality Dremel accessories
  • 2 hour 45 minutes charging plug and seperate USB cable
  • Quick start guide
  • Accessory information sheet
72 GBP
