Drilling
DREMEL® MAX Precision Drill Bit set (628DM) 7 pieces
Drilling
7-piece highly durable drill bit set in various sizes.
  • 7-piece titanium-coated drill bit set in various sizes.
  • Built for durability, made of high-grade stainless steel.
  • Includes a case container to keep your bits organized.
See all variations
12.5 GBP
What you can do with it?
A handy addition to your Dremel toolbox, this titanium-coated Drill Bit Set includes 7 drill bits with a case container to keep bits organized. The bits are ideal for drilling into wood, plastics, soft metals, and drywall. Made of high-grade stainless steel with deep threads and a titanium coating, these drill bits are built for durability. The bits range in sizes from 0.8mm to 3.2mm.
How to use?
Pick the right size for your project. Use the tip of the drill bit to go into the material straight at a 90° angle. All bits have the same 3.2mm shank diameter size, eliminating the need for different mandrels / collets and ensuring faster accessory changes.
Materials to use on:
Can be used on wood, plastics, soft metals and drywall.
Recommended Speed:
20.000 - 30.000 RPM
Shank diameter
WORKING_DIAMETER
Package contents
Price
26150628DM
3.2 mm
mm
7 pieces
£12.50*
  • 7-piece highly durable drill bit set in various sizes.
26150636JA
4 pieces
£13.50*
Wood Drill Bit Set (636) 4 pieces
  • Set of 4 drill bits for drilling into wood
Shank diameter
3.2 mm
Working diameter
0,8, 1,2, 1,6, 2,0, 2,4, 2,8, 3,2 mm
7
7
8710364083459
26150628DM
628DM drilling bit set in a blue container.
Delivery details
  • 7-piece titanium-coated drill bits (0,8mm to 3,2mm)
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.6 cm
12.5 GBP
