Retired Products
Multi-Tool – Precise. Compact. High-Tech.
Compact streamline design: excellent control and precision
Integrated 7,2V Li-Ion battery: no self-discharge, no memory effect: always ready for use thanks to Lithium-Ion technology
Variable speed (5.000-28.000 RPM): optimal speed selection for each application
LED: illuminate the work piece for better accuracy
LED speed indication: easy recognition of the optimal speed
LED fuel indication: easy recognition of battery charge
Docking station: continuous charging and accessory storage
Designed for one purpose – to master all precision DIY projects. Hold this Multi-Tool like a pencil for perfect control and manoeuvrability. The lightweight tool rests comfortably between your thumb and forefinger, which means no discomfort or fatigue, while still feeling strong and sturdy. You can clearly see everything you’re doing with the integrated LED light in the nose cap, even in dark areas. Indicator lights show you the battery level and rotary speed. Go from sanding to engraving to cutting. Know at a glance you are mastering all of your DIY jobs.
Example of usage
Technical details for DREMEL® Micro (8050-35)
Technical specifications
Battery voltage
7,2 V
Battery capacity
1,0 Ah
Charging time
3.75 h
Weight
0,250 kg
19.5 cm
3.5 cm
Depth
3.5 cm
No load speed
5.000 - 28.000 1/min
Battery technology
Lithium-Ion / ECP
No load speed (3)
Speed setting
Variable
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
65 dB(A)
Sound power
76 dB(A)
Vibration
9,8 m/s²
Delivery details: DREMEL® Micro (8050-35)
Dremel Micro
35 high quality Dremel accessories (including EZ SpeedClic accessories)
3 hour 45 minute battery charger (docking station)
Compact storage case
Product box length, 22.1 cm
Product box height, 29.4 cm
Product box width, 8.1 cm
Gross weight, 0,99 kg
F0138050JF
8710364076857
8710364076857
