Retired Products
Retired Products
Multi-Tool – Precise. Compact. High-Tech.
- Compact streamline design: excellent control and precision
- Integrated 7,2V Li-Ion battery: no self-discharge, no memory effect: always ready for use thanks to Lithium-Ion technology
- Variable speed (5.000-28.000 RPM): optimal speed selection for each application
Designed for one purpose – to master all precision DIY projects. Hold this Multi-Tool like a pencil for perfect control and manoeuvrability. The lightweight tool rests comfortably between your thumb and forefinger, which means no discomfort or fatigue, while still feeling strong and sturdy. You can clearly see everything you’re doing with the integrated LED light in the nose cap, even in dark areas. Indicator lights show you the battery level and rotary speed. Go from sanding to engraving to cutting. Know at a glance you are mastering all of your DIY jobs.
