Attachments to Saw
DREMEL® Mini Saw Attachment (670)
Attachments to Saw
Make fine and precise cuts in thin wood, laminate or wooden flooring
  • Have a handheld mini-saw ready at your disposal to cut in wood or wood-like materials.
  • The attachments angled neckline gives you straight, perpendicular cuts, allowing accuracy in your work.
  • Always have clear viability on your project thanks to the clear housing.
See all variations
38.5 GBP
What can you do?
Use your Dremel Multi-Tool as a high speed, handheld mini-saw in no time. Gain the ability to make 6.35mm deep, straight cuts in wood or wood like materials, like laminate.
The angled base of the Mini-Saw attachment prevents the belly of your Dremel Multi-Tool from being in the way of the material your working on.
Perfect for DIY projects when you're in need to make straight cuts on flooring such as laminate or wood as well as plunge cuts in your next arts & crafts and modeling projects.
Blade size of 31.8mm & maximum cutting depth, at 90°,of 6.35mm
How to use
Use on wood or wood like materials for the best cutting results.
Unscrew your Dremel Multi-Tools collet, attach the provided drive cap and screw on the Mini-Saw attachment.
Simply insert your cutting blade, tighten and begin cutting.
Package contents
Price
26150670JD
1 piece
£37.50*
  • Make fine and precise cuts in thin wood, laminate or wooden flooring
26150546JB
2 pieces
£12.50*
Rip/Cross-Cut Blade 31,8 mm (546-2) 2 pieces
  • Long-lasting, mini circular blade that cuts both with and across the grain on wood and wood-like materials
Max working depth
6.4 mm
9 cm
Depth
Suitable Dremel devices
Retired Products
Multi-Tools
8710364082384
26150670JD
User Manuals
Dremel Mini Saw Attachment model 670
Delivery details
  • Mini SawAttachment
  • Rip/Cross-Cut Blade (546)
  • Driver Cap
  • Product box length, 9 cm
  • Product box height, 12 cm
  • Product box width, 6 cm
38.5 GBP
