Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Saws
DREMEL® Moto-Saw Fine Wood Cutting Saw Blade (MS52) 5 pieces
Saws
Saw blade for detailed cuts in wooden materials. This blade has 7 teeth per centimeter ensuring the finest cutting results.
  • Ideal for making straight and curved cuts
  • For use in wood, plastic, foam, carpet and other soft materials
  • Unique pin-end blade design allows quick, tool-free blade changes
See all variations
10.3 GBP
Laminates
Chipboard
Fiberboard
Plywood
Softwood
Hardwood
Plastic
Package contents
Price
2615MS52JA
5 pieces
£10.00*
2608846431
1 piece
£18.00*
DREMEL® Blueprint wood blade (CS500)
  • Your go-to for wood cutting
2608846430
1 piece
£18.00*
DREMEL® Blueprint Multi-Material blade (CS600)
  • Multi-Material Cutting Made Simple
2608847811
1 piece
DREMEL® Blueprint wood fine finish blade (CS900)
  • Your go to blade for smooth, clean, fine finish wood cuts.
2615MS50JA
5 pieces
£12.00*
DREMEL® Moto-Saw Side Cutting Saw Blade (MS50) 5 pieces
2615MS51JA
5 pieces
£10.00*
DREMEL® Moto-Saw General Purpose Wood Cutting Saw Blade (MS51) 5 pieces
2615MS53JA
5 pieces
£10.00*
DREMEL® Moto-Saw Metal Cutting Saw Blade (MS53) 5 pieces
4.0 mm
Total length
100 mm
Cutting depth
12 mm
Teeth per centimeter
7
Blade width
0.2 mm
Blade depth
1.9 mm
3.0 mm
Height
100.0 mm
5
5
Suitable Dremel devices
Saws
DREMEL® Moto-Saw (MS20-1/5)
8710364062836
2615MS52JA
Dremel Moto-Saw Fine Wood Cutting Saw Blade Model MS52
Delivery details
  • Product box length, 1 cm
  • Product box height, 16 cm
  • Product box width, 6.5 cm
  • Gross weight, 0.03 kg
10.3 GBP
