Cutting
DREMEL® Moto-Saw Fine Wood Cutting Saw Blade (MS52)
Saw blade for detailed cuts in wooden materials. This blade has 7 teeth per centimeter ensuring the finest cutting results.
£9.00*
RRP incl. VAT
Example of usage
Technical details for DREMEL® Moto-Saw Fine Wood Cutting Saw Blade (MS52)
Laminates
Chipboard
Fiberboard
Plywood
Softwood
Hardwood
Plastic
Technical specifications
4,0 mm
Total length
100 mm
Cutting depth
12 mm
Teeth per centimeter
7
Blade width
0.2 mm
Blade depth
1.9 mm
Height
100,0 mm
Package Contents
5 pieces
Suitable Dremel devices
Scroll saws
2615MS52JA
8710364062836
Delivery details: DREMEL® Moto-Saw Fine Wood Cutting Saw Blade (MS52)
Product box length, 1 cm
Product box height, 16 cm
Product box width, 6.5 cm
Gross weight, 0,03 kg
2615MS52JA
8710364062836
8710364062836
