Saws
DREMEL® Moto-Saw Metal Cutting Saw Blade (MS53) 5 pieces
Saws
Saw blade for cutting soft sheet metal. This blade has 10 teeth per centimeter ensuring excellent cuts.
- Ideal for making straight and curved cuts
- For use in soft, thin sheet metals
- Unique pin-end blade design allows quick, tool-free blade changes
Soft Metal
DREMEL® Blueprint wood blade (CS500)
- Your go-to for wood cutting
DREMEL® Blueprint Multi-Material blade (CS600)
- Multi-Material Cutting Made Simple
DREMEL® Blueprint wood fine finish blade (CS900)
- Your go to blade for smooth, clean, fine finish wood cuts.
DREMEL® Moto-Saw Side Cutting Saw Blade (MS50) 5 pieces
DREMEL® Moto-Saw General Purpose Wood Cutting Saw Blade (MS51) 5 pieces
DREMEL® Moto-Saw Fine Wood Cutting Saw Blade (MS52) 5 pieces
Suitable Dremel devices
Saws
- Product box length, 1 cm
- Product box height, 16 cm
- Product box width, 6.5 cm
- Gross weight, 0.03 kg
