Saws
DREMEL® Moto-Saw Side Cutting Saw Blade (MS50) 5 pieces
Saws
Saw blade for longer cut offs, which are normally limited by the throat depth of the tool. In terms of technical specifications, this blade is identical to the MS51 General Purpose blade, however, its top and bottom parts are 90 degrees twisted. This twist allows a lateral material feed either from left or right, resulting in technically infinite cuts.
  • Ideal for making straight and curved cuts in larger work pieces
  • For use in wood, plastic, foam, carpet and other soft materials
  • Unique pin-end blade design allows quick, tool-free blade changes
12.3 GBP
Laminates
Chipboard
Fiberboard
Plywood
Softwood
Hardwood
Plastic
4.0 mm
Total length
100 mm
Cutting depth
12 mm
Teeth per centimeter
6
Blade width
0.4 mm
Blade depth
2.5 mm
3.0 mm
Height
100.0 mm
5
5
Suitable Dremel devices
Saws
DREMEL® Moto-Saw (MS20-1/5)
8710364062812
2615MS50JA
Dremel Moto-Saw side cutting saw blade
Delivery details
  • Product box length, 1 cm
  • Product box height, 16 cm
  • Product box width, 6.5 cm
12.3 GBP
