Cutting
DREMEL® Moto-Saw Side Cutting Saw Blade (MS50)
Saw blade for longer cut offs, which are normally limited by the throat depth of the tool. In terms of technical specifications, this blade is identical to the MS51 General Purpose blade, however, its top and bottom parts are 90 degrees twisted. This twist allows a lateral material feed either from left or right, resulting in technically infinite cuts.
£9.00*
RRP incl. VAT
Example of usage
Technical details for DREMEL® Moto-Saw Side Cutting Saw Blade (MS50)
Laminates
Chipboard
Fiberboard
Plywood
Softwood
Hardwood
Plastic
Technical specifications
4,0 mm
Total length
100 mm
Cutting depth
12 mm
Teeth per centimeter
6
Blade width
0.4 mm
Blade depth
2.5 mm
Height
100,0 mm
Package Contents
5 pieces
Suitable Dremel devices
Scroll saws
2615MS50JA
8710364062812
Delivery details: DREMEL® Moto-Saw Side Cutting Saw Blade (MS50)
Product box length, 1 cm
Product box height, 16 cm
Product box width, 6.5 cm
2615MS50JA
8710364062812
8710364062812
