Cutting
DREMEL® Multi-Max 10mm Flush Cut Blade (MM411)
Flush cut blades are used to make precise cuts to allow for installation of flooring or wall trim. Can be used on wood, plastic, drywall and other soft materials.
Technical details for DREMEL® Multi-Max 10mm Flush Cut Blade (MM411)
Chipboard
Fiberboard
Hardwood
Plywood
Softwood
Plastic
Drywall/Plasterboard
Technical specifications
Working diameter
10,0 mm
Package Contents
1 piece
Suitable Dremel devices
Retired Products
2615M411JA
8710364055333
Delivery details: DREMEL® Multi-Max 10mm Flush Cut Blade (MM411)
Product box length, 2 cm
Product box height, 14 cm
Product box width, 10 cm
2615M411JA
8710364055333
8710364055333
