Grinding/sharpening
DREMEL® Multi-Max 60 Grit Diamond Paper (MM900)
Diamond paper accessory for grinding cement, plaster or thin-set mortar. Requires MM11 or MM14 Hook and Loop Pad accessory. For rough grinding, shaping and smoothing of masonry, stone, cement and mortar.
Technical details for DREMEL® Multi-Max 60 Grit Diamond Paper (MM900)
Technical specifications
Grit
60
Package Contents
1 piece
Suitable Dremel devices
Retired Products
2615M900JA
8710364055296
Delivery details: DREMEL® Multi-Max 60 Grit Diamond Paper (MM900)
Product box length, 1 cm
Product box height, 14 cm
Product box width, 10 cm
2615M900JA
8710364055296
8710364055296
