Retired Products
Retired Products
159.99 GBP
The Dremel Multi-Max Kit contains the most relevant accessories focussing mainly on wood working applications while not leaving out other materials: The Hook and Loop Sanding Pad along with the Sanding Papers, the Wood and Metal Flush Cut Blade and the Wood and Drywall Saw blade are all included. This kit also includes 2x 10.8V Li-Ion Batteries with ECP technology for longer working.
Battery voltage
10.8 V
Battery capacity
1.5 Ah
Charging time
1 h
Weight
0.825 kg
25.5 cm
No load speed
3.000 - 21.000 1/min
Battery technology
Lithium-Ion / ECP
Oscillating Angle
L / R 1.5 °
No load speed (3)
Speed setting
Variable
Accessory quick change system
No
Sound pressure
81,5 dB(A)
Sound power
92,5 dB(A)
Vibration
2,8 - 9,1 m/s²
8710364054633
F0138300JB
User Manuals
Delivery details
  • Dremel Multi-Max 8300
  • Wood & Metal Flush Cut Blade
  • Wood & Drywall Saw Blade
  • Hook and Loop Pad
  • 6x Sanding Paper
  • 2x 10.8V Li-Ion 1.3Ah battery pack
  • 1 Hour Charger
  • Instruction manual
  • Sturdy and spacious storage case
  • Product box length, 39.2 cm
  • Product box height, 26.6 cm
  • Product box width, 9.8 cm
  • Gross weight, 2.75 kg
159.99 GBP
