Retired Products
DREMEL® Multi-Max Hook and Loop Sanding Pad (MM11)
Hook and loop pad accessory allows the Multi-Max oscillating tool to accept sand papers and diamond sand paper. Not compatible with MM40.
Technical details for DREMEL® Multi-Max Hook and Loop Sanding Pad (MM11)
  • Chipboard Chipboard
  • Hardwood Hardwood
  • Laminates Laminates
  • Soft Metal Soft Metal
  • Aluminium Aluminium
  • Plastic Plastic
Technical specifications
Package Contents
1 piece
Suitable Dremel devices
2615M011JA
8710364055227
Delivery details: DREMEL® Multi-Max Hook and Loop Sanding Pad (MM11)
Product box length, 2 cm
Product box height, 14 cm
Product box width, 10 cm
2615M011JA
8710364055227
