DREMEL® Multi-Max
DREMEL® Multi-Max MM20 (MM20-1/9)
DREMEL® Multi-Max
119.98 GBP
For this tool the following kit execution is available:
Rated power input
250 W
Voltage
Weight
1.35 kg
24 cm
No load speed
10.000 - 21.000 1/min
Oscillating Angle
L / R 1.5 °
Speed setting
Fully Variable
Accessory quick change system
No
Sound pressure
74 - 78 dB(A)
Sound power
85 - 89 dB(A)
Vibration
2,5 - 5,2 m/s²
8710364063734
F013MM20JB
User Manuals
Order numberF013MM20JB
EAN Code8710364063734
Delivery details- Dremel Multi-Max MM20
- 1x Hook and Loop Sanding Pad (MM11)
- 6x Sanding Paper (3x MM70P, 3x MM70W)
- 1x Wood Flush Cut Blade (MM480)
- 1x Wood & Metal Flush Cut Blade (MM482)
- Vacuum cleaner attachment
- Sturdy and spacious storage case
- Product box length, 39.2 cm
- Product box height, 26.6 cm
- Product box width, 9.8 cm
- Gross weight, 2.86 kg
119.98 GBP
