DREMEL® Multi-Max
DREMEL® Multi-Max
159 GBP
For this tool the following kit execution is available:
Rated power input
270 W
Voltage
Weight
1.47 kg
26.5 cm
No load speed
10.000 - 21.000 1/min
Oscillating Angle
L / R 1.5 °
Speed setting
Fully Variable
Accessory quick change system
Quick Lock
Sound pressure
74 - 78 dB(A)
Sound power
85 - 89 dB(A)
Vibration
2,5 - 5,2 m/s²
8710364063765
F013MM40JB
User Manuals
Dremel MM40 kit
Delivery details
  • Dremel Multi-Max MM40
  • 1x Quick Fit Hook and Loop Sanding Pad (MM14)
  • 6x Sanding Paper (3x MM70P, 3x MM70W)
  • 1x Wood Flush Cut Blade (MM480)
  • 1x Wood & Metal Flush Cut Blade (MM482)
  • Vacuum cleaner attachment
  • Sturdy and spacious storage case
  • Product box length, 9.8 cm
  • Product box height, 26.6 cm
  • Product box width, 39.2 cm
  • Gross weight, 3.00 kg
159 GBP
