Corded Tools
Oscillating tool – Work quickly and easily on heavy duty DIY projects, even for extended periods of time
For this tool the following kit execution is available:
Technical details for DREMEL® Multi-Max MM40 (MM40-1/9)
Technical specifications
Rated power input
270 W
Voltage
Weight
1,47 kg
26.5 cm
No load speed
10.000 - 21.000 1/min
No load speed (3)
Oscillating Angle
L / R 1.5 °
Speed setting
Fully Variable
Accessory quick change system
Quick Lock
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
74 - 78 dB(A)
Sound power
85 - 89 dB(A)
Vibration
2,5 - 5,2 m/s²
Included Accessories (9)
Delivery details: DREMEL® Multi-Max MM40 (MM40-1/9)
Dremel Multi-Max MM40
1x Quick Fit Hook and Loop Sanding Pad (MM14)
6x Sanding Paper (3x MM70P, 3x MM70W)
1x Wood Flush Cut Blade (MM480)
1x Wood & Metal Flush Cut Blade (MM482)
Vacuum cleaner attachment
Sturdy and spacious storage case
Product box length, 9.8 cm
Product box height, 26.6 cm
Product box width, 39.2 cm
Gross weight, 3,00 kg
F013MM40JB
8710364063765
8710364063765
