Sanding
DREMEL® Multi-Max Quick Fit Hook and Loop Pad (MM14)
The Quick Fit Hook & Loop Pad accessory allows Multi-Max oscillating tools to accept sand papers and diamond paper.
Technical details for DREMEL® Multi-Max Quick Fit Hook and Loop Pad (MM14)
Hardwood
Laminates
Chipboard
Stainless Steel
Hardened Steel
Soft Metal
Plastic
Technical specifications
Package Contents
1 piece
Suitable Dremel devices
Retired Products
2615M014JA
8710364064243
Delivery details: DREMEL® Multi-Max Quick Fit Hook and Loop Pad (MM14)
Product box length, 2.5 cm
Product box height, 14.1 cm
Product box width, 10 cm
Gross weight, 0,53 kg
2615M014JA
8710364064243
8710364064243
