Sanding
DREMEL® Multi-Max Sanding Paper for Paint (P80, P120 and P240) (MM70P)
Sand paper accessory to sand paint, varnish and filling compound on a variety of surfaces. Requires Hook and Loop Pad accessory.
Technical details for DREMEL® Multi-Max Sanding Paper for Paint (P80, P120 and P240) (MM70P)
Chipboard
Hardwood
Laminates
Hardened Steel
Soft Metal
Stainless Steel
Plastic
Technical specifications
Grit
80 / 120 / 240
Package Contents
6 pieces
Suitable Dremel devices
Retired Products
2615M70PJA
8710364055241
Delivery details: DREMEL® Multi-Max Sanding Paper for Paint (P80, P120 and P240) (MM70P)
Product box length, 0 cm
Product box height, 14 cm
Product box width, 10 cm
2615M70PJA
8710364055241
8710364055241
