Sanding
DREMEL® Multi-Max Sanding Paper for Wood (P60, P120 and P240) (MM70W)
Sand paper accessory for sanding hardwood, softwood, chipboard, rusted metal, fibreglass and plastics. Requires MM11 or MM14 Hook and Loop Pad accessory.
Technical details for DREMEL® Multi-Max Sanding Paper for Wood (P60, P120 and P240) (MM70W)
Chipboard
Hardwood
Laminates
Hardened Steel
Soft Metal
Stainless Steel
Plastic
Technical specifications
Grit
60 / 120 / 240
Package Contents
6 pieces
Suitable Dremel devices
Retired Products
2615M70WJA
8710364055234
Delivery details: DREMEL® Multi-Max Sanding Paper for Wood (P60, P120 and P240) (MM70W)
Product box length, 0 cm
Product box height, 14 cm
Product box width, 10 cm
Gross weight, 0,04 kg
2615M70WJA
8710364055234
8710364055234
