Retired Products
Dremel (MM721)
Spiral Cutting Blades are used to do intricate and very detailed cuts and trims. These blades can be used only with the MM720 Multi-Flex.
Technical details for DREMEL® Multi-Max Spiral Cutting Blades (MM721)
- Chipboard
- Fiberboard
- Hardwood
- Plywood
- Softwood
- Plastic
- Drywall/Plasterboard
- Laminates
Technical specifications
Working length
50 mm
Delivery details: DREMEL® Multi-Max Spiral Cutting Blades (MM721)
Product box length, 1.8 cm
Product box height, 14.1 cm
Product box width, 5 cm
2615M721JA
8710364056026
8710364056026
