Cutting
DREMEL® Multi-Max Wood and Drywall Saw Blade (MM450)
Wood & Drywall Saw Blades are ideal for making precise cuts in wood, plaster and drywall material.
Technical details for DREMEL® Multi-Max Wood and Drywall Saw Blade (MM450)
Chipboard
Fiberboard
Hardwood
Plywood
Softwood
Plastic
Laminates
Drywall/Plasterboard
Technical specifications
Working diameter
75,0 mm
Package Contents
1 piece
Suitable Dremel devices
Retired Products
2615M450JA
8710364055265
Delivery details: DREMEL® Multi-Max Wood and Drywall Saw Blade (MM450)
Product box length, 0 cm
Product box height, 14 cm
Product box width, 10 cm
Gross weight, 0,03 kg
2615M450JA
8710364055265
8710364055265
