Retired Products
Cutting Blades
DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM482)
Retired Products
Cutting Blades
The Wood and Metal Flush Cut Blade (MM482) is Dremel’s largest and fastest bi-metal flush cut blade with the ability to perform precise flush and plunge cuts. Especially designed for metal. Can cut non-ferrous metals, nails, wood, plastic, drywall and other soft material.
- Universal Quick Fit blades are compatible with Dremel, Bosch, Makita, Milwaukee, and Rockwell
- BiMetal (BiM) blade material- for wood and metal cutting applications
- High performance flush cut blade—provides longest life and fastest cut of all Dremel BiM flush cut blades
Stainless Steel
Plastic
Hardwood
Softwood
Laminates
Chipboard
Soft Metal
DREMEL® Multi-Max Multi-Knife (MM430)
DREMEL® Multi-Max Jab Saw Blade (MM435)
DREMEL® Multi-Max Wood and Drywall Saw Blade (MM450)
Suitable Dremel devices
Retired Products
- Product box length, 2 cm
- Product box height, 14 cm
- Product box width, 10 cm
- Gross weight, 0.04 kg
