Cutting
DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM422)
Flush cut blades are used to make precise cuts and plunge cuts. Can be used on non-ferrous metals, wood, plastic, drywall and other soft materials.
Technical details for DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM422)
Chipboard
Hardwood
Laminates
Soft Metal
Plastic
Technical specifications
Working diameter
20,0 mm
Package Contents
1 piece
Suitable Dremel devices
Retired Products
2615M422JA
8710364055258
Delivery details: DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM422)
Product box length, 1.8 cm
Product box height, 14 cm
Product box width, 10 cm
2615M422JA
8710364055258
8710364055258
