Cutting
DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM482)
The Wood and Metal Flush Cut Blade (MM482) is Dremel’s largest and fastest bi-metal flush cut blade with the ability to perform precise flush and plunge cuts. Especially designed for metal. Can cut non-ferrous metals, nails, wood, plastic, drywall and other soft material.
Technical details for DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM482)
Stainless Steel
Plastic
Hardwood
Softwood
Laminates
Chipboard
Soft Metal
Technical specifications
Working diameter
32,0 mm
Package Contents
1 piece
Suitable Dremel devices
Retired Products
2615M482JA
8710364064281
Delivery details: DREMEL® Multi-Max Wood and Metal Flush Cut Blade (MM482)
Product box length, 2 cm
Product box height, 14 cm
Product box width, 10 cm
Gross weight, 0,04 kg
2615M482JA
8710364064281
8710364064281
