Retired Products
DREMEL® Multi-Max Wood Flush Cut Blade (MM480)
Retired Products
17.36 GBP
Hardwood
Softwood
Laminates
Chipboard
Plywood
Fiberboard
Drywall/Plasterboard
Plastic
The Wood Flush Cut Blade (MM480) is Dremel’s largest and fastest high-carbon steel flush cut blade with the ability to perform precise plunge cuts and flush cuts allowing for installation of flooring or wall trim. Especially designed for wood. Can also cut plastic, drywall and other soft materials.
Working diameter
32.0 mm
Suitable Dremel devices
Retired Products
8710364064274
2615M480JA
Order number2615M480JA
EAN Code8710364064274
Delivery details- Product box length, 2 cm
- Product box height, 14 cm
- Product box width, 10 cm
- Gross weight, 0.04 kg
17.36 GBP
