Retired Products
Dremel (MM480)
The Wood Flush Cut Blade (MM480) is Dremel’s largest and fastest high-carbon steel flush cut blade with the ability to perform precise plunge cuts and flush cuts allowing for installation of flooring or wall trim. Especially designed for wood. Can also cut plastic, drywall and other soft materials.
Technical details for DREMEL® Multi-Max Wood Flush Cut Blade (MM480)
- Hardwood
- Softwood
- Laminates
- Chipboard
- Plywood
- Fiberboard
- Drywall/Plasterboard
- Plastic
Technical specifications
Working diameter
32,0 mm
Suitable Dremel devices
Retired Products
2615M480JA
8710364064274
Delivery details: DREMEL® Multi-Max Wood Flush Cut Blade (MM480)
Product box length, 2 cm
Product box height, 14 cm
Product box width, 10 cm
Gross weight, 0,04 kg
2615M480JA
8710364064274
8710364064274
