Routing
Accessory Kits
DREMEL® Multipurpose Router Bit Set (660)
Routing
Accessory Kits
Veneered woods
Fiberboard
Chipboard
Laminates
Plywood
Softwood
Hardwood
Rubber
Plastic
Plexiglass
Carbon
The 7 piece Dremel Multipurpose Router Bit Set contains all seven of Dremel's high quality routing accessories. With this accessory set you can perform a diverse range of routing applications; Edge, Corner, Straight, Keyhole, Word & Letter Routing in a variety of materials including but not limited to Hardwood, Softwood, Plywood and Laminates. Rout slots in doors to fix new door handles, design and rout your own kitchen cabinets or create your own house number. Conveniently store your bits in the included wooden box.
- Set of 7 routing accessories to rout in a variety of materials
EZ SpeedClic Cutting Accessory Set (SC690)
- Set of 10 EZ SpeedClic cutting wheels + mandrel for cutting in metals and plastics
EZ SpeedClic Multipurpose Accessory Set (SC725)
- Multipurpose kit with 70 high quality EZ SpeedClic accessories for various applications and materials
Router Bit (HSS) 9,5 mm (612)
- For making a round edge to your wooden workpiece
Router Bit (HSS) 9,5 mm (615)
Router Bit (HSS) 6,4 mm (640)
- For inlaying and routing a V groove in wood
Router Bit (HSS) 3,2 mm (650)
- Smallest straight edge router bit. For routing in wood
Router Bit (HSS) 4,8 mm (652)
- Second to smallest straight edge router bit. For routing in wood
Router Bit (HSS) 6,4 mm (654)
- Second to biggest straight edge router bit. For routing in wood
Router Bit (HSS) 8,0 mm (655)
- Biggest straight edge router bit. For routing in wood
Woodworking Set (681)
- 20 pieces Woodworking Accessory Set
Glass Etching Set (682)
- 8 pieces Glass Etching Accessory Set
Cleaning / Polishing Set (684)
- Ideal starter set for cleaning and polishing including 20 accessories
Multipurpose Set (687)
- Set of accessories for cutting, carving, sanding, cleaning, polishing, grinding and sharpening
Cutting Set (688)
- Set of 68 cutting accessories to cut in a variety of materials
100 pieces DREMEL® Multipurpose Accessory Set (723)
- Ideal Dremel starter kit with 100 accessories for various applications and materials
150 pieces DREMEL® Multipurpose Accessory Set (724)
- Ideal Dremel starter kit with 150 accessories for a wide range of applications and materials
- Product box length, 15 cm
- Product box height, 25 cm
- Product box width, 95 cm
- Gross weight, 0.07 kg
