Attachments to Rout
DREMEL® Plunge Router Attachment (335)
Attachments to Rout
Transform your Dremel Multi-Tool into a plunge router.
  • Turn your Dremel Multi-Tool in to a compact Plunge Router, great for lighter routing projects.
  • The transparent base allows you to rout with visbility of your workpiece for greater accuracy.
  • Have the ability to create curved edges, straight slots or start routing in the middle of your workpiece for inlay work
See all variations
38 GBP
What can you with it?
Transform your Dremel Multi-Tool into a lightweight, free to hold plunge router.Have full accuracy, stability and control with your Dremel Multi-Tool and the Plunge Router attachment for your smaller to medium sized routing projects. When working with materials like wood, gain a quick way to get curved edges, straight slots or have the freedom to start routing in the middle of your workpiece for inlays or keyhole slots. The transparent, plastic base of the attachment ensures a clear view of your project and won't damage your material. Achieve smooth and consistent cuts thanks to the possibility to lock your routing depth.
How to use
Mount your routing accessory to your Dremel Multi-Tool, screw and tighten the Plunge Router with the included wrench and you are ready to go! . When beginning your routing project, set the recommended RPM on your Multi-Tool and let the tool do the work by moving slowly in your material to prevent burning your workpiece. Plunge into your material by allowing your accessory to glide into your workpiece for a smooth start. You can easily guide the attachment over your workpiece by holding the grips with both hands. Choose to lock the attachment at your desired routing depth or have it unlocked to freely rout at variable depths. For clean results, rout in phases taking off a layer at a time until you are at your desired depth. Use the included circle or line guides to rout perfect circles or sharp, straight lines.
Package contents
Price
26150335JA
1 piece
£37.00*
  • Transform your Dremel Multi-Tool into a plunge router.
26150655JA
1 piece
£22.00*
Router Bit (HSS) 8,0 mm (655)
  • Biggest straight edge router bit. For routing in wood
2615061532
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (615)
  • For making a round edge to your wooden workpiece
2615061232
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (612)
2615065032
1 piece
£11.00*
Router Bit (HSS) 3,2 mm (650)
  • Smallest straight edge router bit. For routing in wood
2615064032
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (640)
  • For inlaying and routing a V groove in wood
26150660JA
1 piece
£46.00*
DREMEL® Multipurpose Router Bit Set (660)
  • Set of 7 routing accessories to rout in a variety of materials
2615065432
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (654)
  • Second to biggest straight edge router bit. For routing in wood
2615065232
1 piece
£11.00*
Router Bit (HSS) 4,8 mm (652)
  • Second to smallest straight edge router bit. For routing in wood
Working length
70,0 mm
22 cm
12.5 cm
Depth
18 cm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364023080
26150335JA
User Manuals
Multi-Tool  fixed on a Plunge Router Attachment 335
Delivery details
  • Plunge Router Attachment
  • Edge Guide
  • Circle Guide
  • Guide Bushing Set
  • Wrench
  • Product box length, 13 cm
  • Product box height, 23.7 cm
  • Product box width, 15 cm
38 GBP
