Attachments to Reach
DREMEL® Right Angle Attachment (575)
Get the right angle to tackle the hard-to-reach places
- Get all the uses of your Dremel Multi-Tool in tight, small spaces with 12, easy to change directions.
- The fixed 90°, angled head of the attachment keeps the tool sturdy as well as provides visibility to your workpiece or surface.
- Attaches to your Multi-Tool in a few simple steps to allow you to jump in to your projects quickly.
What can you do with it?
Get into those hard-to-reach areas by using the Right Angle attachment in combination with your Dremel Multi-Tool while cutting, drilling, grinding and more. You can reach almost all awkward positions thanks to the coupling system which enables to use it in 12 different directions.. Just screw on the Right Angle attachment with the quick connect system onto your Multi-Tool and you're good to go. The durable design with ball bearing and spiral bevel ensures smooth and cool operations, project after project. "
How to use?
Unscrew the collet and remove the collet nut from your Dremel Multi-Tool. Screw on the included drive cap before mounting the Right Angle attachment. Easily install the collet and collet nut onto the Right Angle attachment and insert your chosen Dremel accessory. Tighten, choose your preferred angle and start cutting, sanding, grinding, drilling and more in the hard-to-reach area.
- Get the right angle to tackle the hard-to-reach places
DREMEL® Flexible Shaft (225)
- Experience even more precision and manoeuvrability, even in hard-to-reach places
Suitable Dremel devices
Retired Products
Multi-Tools
User Manuals
- Right Angle Attachment
- Driver Cap
- Product box length, 9 cm
- Product box height, 12 cm
- Product box width, 4 cm
