Corded Tools
DREMEL® ScrollStation (1800-1/5)
The Dremel ScrollStation is the most richly featured, most user-friendly and easy to control scrollsaw in the market. Its size and sturdiness, up front mounted controls, integrated disc sander and power take-off port allow you to work effortlessly and with high precision on a variety of detailed woodworking or other projects.
Technical details for DREMEL® ScrollStation (1800-1/5)
Technical specifications
Rated power input
110 W
Voltage
Weight
24,00 kg
No load speed
500 1.500 1/min
Cutting depth
470 mm
Precision tip
Dual temperature
Removable cord
Drip control
Delivery details: DREMEL® ScrollStation (1800-1/5)
Scroll saw
Disc Sander
5 scroll saw blades
Instruction manual
Gross weight, 27,17 kg
F0131800JB
8710364035014
8710364035014
