Attachments to Control
DREMEL® Shaping Platform Attachment (576)
Sharpen, grind and sand edges at perfect 90 or 45 degree angles
- Sand, sharpen or grind at accurate 45°/90° angles with your compatible Dremel Multi-Tool.
- Use to finish your cuts making them accurate, sharp and clean.
- 20mm of adjustment to the shaping platform when attaching to your Dremel Multi-Tool to fine tune the attachment to your project for ultimate precision.
What can you do with it?
The Dremel Shaping platform attachment adds precision to your work by giving your Dremel Multi-Tool a 45° or 90° sanding, sharpening or grinding angle.
Perfect for finishing a cut using the included 60 grit sanding band and mandrel accessory (407).
Great for sharpening and shaping up your garden equipment, such as shears, to a clean 45° angle using the included Grinding Stone accessory (932).
How to use?
Insert and tighten the provided accessory and effortlessly screw on the shaping platform. Adjust the platform up to 20mm, tighten and create the perfect 45°/90° by holding it against your work piece.
For best results, use with 2 hands and slowly slide your Multi-Tool along your work piece until the platform and material are aligned.
Tip: Use with a Dremel Multi-Vise to transform your Dremel Multi-Tool into a benchtop shaping platform.
- Sharpen, grind and sand edges at perfect 90 or 45 degree angles
DREMEL® Workstation (220)
- Use the Workstation as a drill press (any angle), tool holder or tool hanger for your Dremel projects
DREMEL® Flex-Shaft Tool Holder (2222)
- Safely hang your Dremel Multi-Tool with Flexible Shaft for even more control and convenience
DREMEL® Multi-Vise (2500)
- Have total control over your project with the 3-in-1 and 360° stationary vise, standalone clamp and tool holder.
DREMEL® Comfort Guard (550(1))
- Clear and simple solution for redirecting debris and sparks
DREMEL® Detailer's Grip Attachment (577)
- Get an even better ergonomic grip for more comfort, precision and control
Suitable Dremel devices
Retired Products
Multi-Tools
- Shaping Platform Attachment
- 407 Sanding Mandrel and Band
- 932 Grinding Stone
- Product box length, 9 cm
- Product box height, 12 cm
- Product box width, 4 cm
