Corded Tools
Maker Kit
Limited edition: Dremel Stylo+ Multi-Tool for crafters with necessary crafter essential accessories
Be precise - the tools slim size allows you to get closer to your work piece
Dive into your craft projects. With this kit you can sand, engrave, polish and more on a variety of materials
The Dremel Stylo+ is built to be used in your home with its quiet compact motor
Craft it yourself using the Dremel Stylo +. A tool that brings precision with ease to your projects. This kit includes the crafters essential Stylo + and 10 accessories which allow you to explore different applications. Pairing this with the 2m long cord, the tool has great maneuverability for you to complete your wide range of applications including carving, engraving, polishing, cleaning and sanding on a wide range of materials.
Technical details for DREMEL® Stylo+ (2050-10)
Technical specifications
Rated power input
9 W
Voltage
Weight
0,11 kg
Depth
2.3 cm
No load speed
5.000 - 22.000 1/min
No load speed (3)
Speed setting
Variable
Accessory quick change system
No
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
Vibration
Included accessories (10)
Overview of prices and delivery details
Order number: F0132050UB
EAN Code: 8710364080618
£40.00
See delivery details
Dremel Stylo+ tool
10 high quality Dremel accessories
Quick Start Guide
Tool- and accessory storage
Product box length, 28.7 cm
Product box height, 5.7 cm
Product box width, 16.5 cm
Gross weight, 0,50 kg
Order number: F0132050JB
EAN Code: 8710364080199
£56.00
Dremel Stylo+
15 high quality Dremel accessories
Quick Start Guide
Gross weight, 0,52 kg
