Corded Tools
Multi-Tool – Versatile. Precise. Made for creatives and crafters.
Variable speed (5,000 to 22,000): For precise applications on creative DIY & craft projects.
Compact and lightweight design with 2-meter cord: Makes the tool easy and comfortable to use.
Ergonomic grip: Provides comfort and control for maximum precision.
Recessed collet lock: Prevents any interfering with the operation.
Separate on/off button: Saves your rotary speed settings even when the appliance is powered on and off.
The versatile Dremel Stylo+ is the ideal tool for creating the perfect finish on your DIY and craft projects The thin light weighted design lets you hold the tool just like an ordinary pen. With its comfortable handling and ease of use you can tackle creative DIY designs that require long extended periods of time and precision. Together with the 2-meter long cord, the tool allows you great maneuverability for your engraving, carving, cleaning and polishing applications on a wide range of materials.
Example of usage
Technical details for DREMEL Stylo+ (2050-15)
Technical specifications
Rated power input
9 W
Voltage
Weight
0,11 kg
Depth
2.3 cm
No load speed
5.000 - 22.000 1/min
No load speed (3)
Speed setting
Variable
Accessory quick change system
Multi Chuck
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
Vibration
Included accessories (15)
Overview of prices and delivery details
Order number: F0132050UB
EAN Code: 8710364080618
£40.00
See delivery details
Dremel Stylo+ tool
10 high quality Dremel accessories
Quick Start Guide
Tool- and accessory storage
Product box length, 28.7 cm
Product box height, 5.7 cm
Product box width, 16.5 cm
Gross weight, 0,50 kg
Order number: F0132050JB
EAN Code: 8710364080199
£56.00
Dremel Stylo+
15 high quality Dremel accessories
Quick Start Guide
Gross weight, 0,52 kg
