Multi-Tools DIY Arts & Crafts
DREMEL Stylo+
DREMEL Stylo+
DREMEL Stylo+
DREMEL Stylo+
DREMEL Stylo+ DREMEL Stylo+ DREMEL Stylo+ DREMEL Stylo+
Multi-Tool – Versatile. Precise. Made for creatives and crafters.
  • Variable speed (5,000 to 22,000): For precise applications on creative DIY & craft projects.
  • Compact and lightweight design with 2-meter cord: Makes the tool easy and comfortable to use.
  • Ergonomic grip: Provides comfort and control for maximum precision.
  • Recessed collet lock: Prevents any interfering with the operation.
  • Separate on/off button: Saves your rotary speed settings even when the appliance is powered on and off.
£58.00* RRP incl. VAT
The versatile Dremel Stylo+ is the ideal tool for creating the perfect finish on your DIY and craft projects The thin light weighted design lets you hold the tool just like an ordinary pen. With its comfortable handling and ease of use you can tackle creative DIY designs that require long extended periods of time and precision. Together with the 2-meter long cord, the tool allows you great maneuverability for your engraving, carving, cleaning and polishing applications on a wide range of materials.
Example of usage
Functions and Advantages of DREMEL Stylo+ (2050-15)
Variable speed for a wide range of applications
Multichuck to quickly change accessories regardless of their size
Technical details for DREMEL Stylo+ (2050-15)
Technical specifications
Rated power input
9 W
Voltage
Weight
0,11 kg
Depth
2.3 cm
No load speed
5.000 - 22.000 1/min
No load speed (3)
Speed setting
Variable
Accessory quick change system
Multi Chuck
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
Vibration
Delivery details: DREMEL Stylo+ (2050-15)
Dremel Stylo+
15 high quality Dremel accessories
Quick Start Guide
Product box length, 32.7 cm
Product box height, 6.1 cm
Product box width, 16.7 cm
Gross weight, 0,61 kg
F0132050JB
8710364080199
Recommended products:
DREMEL® Multi-Vise
£41.00* RRP incl. VAT
Engraving Bit DREMEL® MAX
£10.50* RRP incl. VAT
Tungsten Carbide Carving bit DREMEL® MAX
£14.50* RRP incl. VAT
£20.00* RRP incl. VAT
£17.50* RRP incl. VAT
Glass Etching Set
£21.00* RRP incl. VAT
Manuals
Download User manual
