Multi-Tools
Arts & Crafts
Multi-Tools
Arts & Crafts
Multi-Tool in pen-form. Made for creatives and crafters.
  • The thin light weighted design lets you hold the tool just like an ordinary pen.
  • Whether it's engraving designs, performing light sanding, or polishing finishes, this tool is your go-to companion for a wide range of crafting needs.
  • Adjust the speed to your liking with variable speed settings, tailored to your project needs.
59 GBP
Pen Like Design
You know that feeling when you're gripping your favorite pen, and it just feels right in your hand? Well, imagine that same comfort, but with a Multi-Tool instead. It's like an extension of your hand – lightweight, easy to handle, and totally natural. And here's the beauty of it: You don't need any prior experience with Multi-tools. It's as intuitive as holding a pen, so you can dive right in without any hesitation. Plus, that pen-like form not only offers comfort but also brings precision to your projects.
Precision Control for Diverse Applications
Adjust the speed from 5,000 to 22,000 RPM for precise handling in a variety of craft projects. Whether you're etching glass or engraving wood, this tool's variable speed ensures accuracy, enhancing your crafting experience. The Dremel Stylo+ is ideal for sanding, engraving/carving, and cleaning/polishing tasks.
Long Cord for Great Reach
Benefit from a generous 2-meter cord, enabling comfortable and flexible use without limitations. Enjoy the freedom to maneuver through various workspaces effortlessly.
Effortless Accessory Changes
Enjoy hassle-free accessory swaps with our wrench-free system. The keyless chuck securely holds accessories, facilitating quick and easy changes.
Discover Creative Versatility with the Dremel Stylo+ Kit
Unlock a world of creative possibilities with this kit, featuring a versatile selection of 15 accessories. From sanding and polishing to cleaning and intricate wood and glass engraving, this kit provides everything you need to tackle a wide range of creative projects. Dive into your artistic endeavors with confidence, knowing that the Dremel Stylo+ and its comprehensive accessory kit are here to inspire your imagination and elevate your craftsmanship to new heights.
Variable speed for a wide range of applications
Multichuck to quickly change accessories regardless of their size
Rated power input
9 W
Voltage
Weight
0.11 kg
Depth
2.3 cm
No load speed
5.000 - 22.000 1/min
No load speed (3)
Speed setting
Variable
Accessory quick change system
Multi Chuck
Sound pressure
Vibration
8710364083152
F0132050JN
User Manuals
A Dremel Stylo+ with 10 accessories and images of projects that can be done with the tool
Delivery details
  • Dremel Stylo+
  • 15 high quality Dremel accessories
  • Quick Start Guide
  • Product box length, 32.7 cm
  • Product box height, 6.1 cm
  • Product box width, 16.7 cm
  • Gross weight, 0.61 kg
59 GBP
