Retired Products
Retired Products
Maker Kit
  • Limited edition: Dremel Stylo+ Multi-Tool for crafters with necessary crafter essential accessories
  • Be precise - the tools slim size allows you to get closer to your work piece
  • Dive into your craft projects. With this kit you can sand, engrave, polish and more on a variety of materials
49.99 GBP
Craft it yourself using the Dremel Stylo +. A tool that brings precision with ease to your projects. This kit includes the crafters essential Stylo + and 10 accessories which allow you to explore different applications. Pairing this with the 2m long cord, the tool has great maneuverability for you to complete your wide range of applications including carving, engraving, polishing, cleaning and sanding on a wide range of materials.
Variable speed for a wide range of applications
Multichuck to quickly change accessories regardless of their size
Rated power input
9 W
Voltage
Weight
0.11 kg
Depth
2.3 cm
No load speed
5.000 - 22.000 1/min
Speed setting
Variable
Accessory quick change system
No
Sound pressure
Vibration
8710364080618
F0132050UB
User Manuals
Delivery details
  • Dremel Stylo+ tool
  • 10 high quality Dremel accessories
  • Quick Start Guide
  • Tool- and accessory storage
  • Product box length, 28.7 cm
  • Product box height, 5.7 cm
  • Product box width, 16.5 cm
  • Gross weight, 0.50 kg
49.99 GBP
