Retired Products
Dremel (TR618)
For routing decorative edges in wood and other soft materials. Made of high-speed steel. For use with the Dremel Trio tool.
Ideal for routing chamfered edges, inlaying and mortising in wood and other soft materials
Used on wood and other soft materials
Easy for novice users to get started, precision for advanced users
One handed ergonomic solution for routing
Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO Chamfer Router Bit (TR618)
- Hardwood
- Softwood
- Rubber
- Plastic
- Plexiglass
- Carbon
Technical specifications
Shank diameter
4,8 mm
Working diameter
9,5 mm
Delivery details: DREMEL® TRIO Chamfer Router Bit (TR618)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
2615T618JA
8710364053735
8710364053735
