Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Retired Products
DREMEL® TRIO Multipurpose Carbide Cutting Bit (TR563)
Retired Products
23.13 GBP
Drywall/Plasterboard
Chipboard
Fiberboard
Hardwood
Laminates
Plywood
Softwood
Plastic
Plexiglass
Soft Metal
The Dremel TRIO Multipurpose Carbide Cutting Bit cuts wood, drywall, plastic, fiberglass, laminate and sheet metal. Carbide bits last longer than traditional HSS bits.
Decidated accessory for use with Dremel Trio only.
Shank diameter
4.8 mm
Working diameter
3.2 mm
8710364053698
2615T563JA
Dremel TRIO Multipurpose Carbide Cutting Bit (TR563)
Delivery details
  • Product box length, 2 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
23.13 GBP
