Retired Products
Dremel (TR563)
The Dremel TRIO Multipurpose Carbide Cutting Bit cuts wood, drywall, plastic, fiberglass, laminate and sheet metal. Carbide bits last longer than traditional HSS bits.Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO Multipurpose Carbide Cutting Bit (TR563)
- Drywall/Plasterboard
- Chipboard
- Fiberboard
- Hardwood
- Laminates
- Plywood
- Softwood
- Aluminium
- Plastic
- Plexiglass
- Soft Metal
Technical specifications
Shank diameter
4,8 mm
Working diameter
Delivery details: DREMEL® TRIO Multipurpose Carbide Cutting Bit (TR563)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
2615T563JA
8710364053698
8710364053698
