Retired Products
DREMEL® TRIO P120 Sanding Band (TR432) 4 pieces
Retired Products
2.66 GBP
Hardwood
Softwood
Soft Metal
Brass
Hardened Steel
Stainless Steel
Rubber
Plastic
Plexiglass
The Dremel TRIO P120 Sanding Band for fine (Grit 120) shaping and smoothing wood and fibreglass, removing rust from metal surfaces and shaping rubber surfaces. Sanding bands are easily replacable.
Decidated accessory for use with Dremel Trio only.
Working diameter
13,0 mm
Grit
120
4
4
8710364053650
2615T432JA
Order number2615T432JA
EAN Code8710364053650
Delivery details- Product box length, 2.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
2.66 GBP
