Retired Products
Dremel (TR432)
The Dremel TRIO P120 Sanding Band for fine (Grit 120) shaping and smoothing wood and fibreglass, removing rust from metal surfaces and shaping rubber surfaces. Sanding bands are easily replacable.Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO P120 Sanding Band (TR432)
- Hardwood
- Softwood
- Soft Metal
- Aluminium
- Brass
- Hardened Steel
- Stainless Steel
- Rubber
- Plastic
- Plexiglass
Technical specifications
Working diameter
13,0 mm
Grit
120
Delivery details: DREMEL® TRIO P120 Sanding Band (TR432)
Product box length, 2.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615T432JA
8710364053650
8710364053650
