Sanding
DREMEL® TRIO P60 Sanding Band (TR408)
The Dremel TRIO P60 Sanding Band for rough (Grit 60) shaping and smoothing wood and fibreglass, removing rust from metal surfaces and shaping rubber surfaces. Sanding bands are easily replacable.Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO P60 Sanding Band (TR408)
Hardwood
Softwood
Soft Metal
Brass
Hardened Steel
Stainless Steel
Rubber
Plastic
Plexiglass
Technical specifications
Working diameter
13,0 mm
Grit
60
Package Contents
4 pieces
Delivery details: DREMEL® TRIO P60 Sanding Band (TR408)
Product box length, 2.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615T408JA
8710364053643
8710364053643
