Carving/Engraving/Routing
DREMEL® TRIO Router Bit Set (TR675)
A set of various size special carbide router bits. These router bits have been specially engineered to work with the Dremel® TRIO. Kit includes a beading, a rabbet, a flush trim, a cove and a V-groove bit.
Technical details for DREMEL® TRIO Router Bit Set (TR675)
Hardwood
Softwood
Chipboard
Technical specifications
Shank diameter
4,8 mm
Working diameter
null mm
Package Contents
5 pieces
Delivery details: DREMEL® TRIO Router Bit Set (TR675)
1x Beading Bit 4,76 mm
1x Rabbet Bit 6,35 mm
1x Flush Trim Bit 6,35 mm
1x Cove Bit 6,35 mm
1x V-Groove Bit 12,7 mm
Product box length, 3 cm
Product box height, 12 cm
Product box width, 9 cm
2615T675JA
8710364058013
8710364058013
