Retired Products
DREMEL® TRIO Sanding Mandrel (TR407) 3 pieces
Retired Products
3.24 GBP
Hardwood
Softwood
Soft Metal
Brass
Hardened Steel
Stainless Steel
Rubber
Plastic
Plexiglass
The Dremel TRIO Sanding Mandrel for rough shaping and smoothing wood and fibreglass, removing rust from metal surfaces and shaping rubber surfaces. Sanding bands are easily replaceable.
Decidated accessory for use with Dremel Trio only.
Shank diameter
4.8 mm
Working diameter
13.0 mm
Grit
60
3
3
8710364053667
2615T407JA
Order number2615T407JA
EAN Code8710364053667
Delivery details- 1 Sanding Mandrel
- 2 Sanding Bands (P60)
- Product box length, 2.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
3.24 GBP
