Sanding
DREMEL® TRIO Sanding Mandrel (TR407)
The Dremel TRIO Sanding Mandrel for rough shaping and smoothing wood and fibreglass, removing rust from metal surfaces and shaping rubber surfaces. Sanding bands are easily replaceable.Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO Sanding Mandrel (TR407)
Hardwood
Softwood
Soft Metal
Brass
Hardened Steel
Stainless Steel
Rubber
Plastic
Plexiglass
Technical specifications
Shank diameter
4,8 mm
Working diameter
13,0 mm
Grit
60
Package Contents
3 pieces
Delivery details: DREMEL® TRIO Sanding Mandrel (TR407)
1 Sanding Mandrel
2 Sanding Bands (P60)
Product box length, 2.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615T407JA
8710364053667
8710364053667
