Carving/Engraving/Routing
DREMEL® TRIO Straight Router Bit Set (TR673)
A set of various size carbide straight router bits for routing and inlaying in wood.(Dedicated accessories for use with Dremel Trio only.)
Technical details for DREMEL® TRIO Straight Router Bit Set (TR673)
Hardwood
Softwood
Chipboard
Technical specifications
Shank diameter
4,8 mm
Working diameter
null mm
Package Contents
3 pieces
Delivery details: DREMEL® TRIO Straight Router Bit Set (TR673)
1x Straight Router bit 12,7 mm
1x Straight Router bit 6,35 mm
1x Straight Router bit 3,175 mm
Product box length, 2 cm
Product box height, 12 cm
Product box width, 9 cm
2615T673JA
8710364058006
8710364058006
