Cutting
DREMEL® TRIO Wall Tile Cutting Bit (TR562)
The Dremel TRIO Wall Tile Cutting Bit cuts ceramic wall tiles, plaster and cement board easily.Decidated accessory for use with Dremel Trio only.
Technical details for DREMEL® TRIO Wall Tile Cutting Bit (TR562)
Drywall/Plasterboard
Ceramic
Wall Tile
Technical specifications
Shank diameter
4,8 mm
Working diameter
Package Contents
1 piece
Delivery details: DREMEL® TRIO Wall Tile Cutting Bit (TR562)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
2615T562JA
8710364053704
8710364053704
