Cordless Tools
DREMEL® Versa (PC10-1/10)
High Speed Power Cleaner - All your Cleaning Supplies in One
Multi-purpose cleaner – swap the quick change spin brush or pads to fit your specific cleaning job. From cleaning surfaces that require non-scratch scrubbing, such as pots and pans or sinks, to more aggressive cleaning, like removing burnt-on grease off of a grill or removing soap scum. The best solution for easily scrubbing grime, mold, mildew, grease, soap scum, limescale, bug splatter and tar, gunk, rust and more
Power scrubber – high rotation speed lets you overcome even the toughest, dirtiest cleaning jobs making it a breeze to clean dirty stove tops, ovens, pots and pans, shower glass, tile grout, drains, sneakers and boots, golf clubs, grills, and more
Efficient - Powered by USB fast charging Lithium-Ion battery for small, but tough cleaning applications. In addition to all your indoor house cleaning jobs, your outdoor cleaning tasks are swiftly taken care of with this compact, portable cleaning tool. Even on wet surfaces and with or without the use of water or cleaner
Compact – the ergonomic design of the Versa cleaning tool provides perfect control and fits comfortably in the palm of your hand
£75.00*
RRP incl. VAT
Save time with all your difficult cleaning jobs. The Dremel® Versa all-purpose cleaner is perfect for both wet and dry uses, functioning as an oven cleaner, bathroom tile or shower glass cleaner, shoe cleaner and much more. All in one cleaning tool. Whether you’re kitchen cleaning or car detailing, the lightweight and compact design allows you to get into those hard to reach places. Both indoor and outdoor. Thanks to the four quick change spin brush and cleaning pads, including a non-scratch pad and heavy duty pad, this multi-purpose cleaner can be used both on delicate surfaces and on surfaces that allow for more aggressive cleaning. Eliminate elbow grease and effortlessly power clean the toughest surfaces.
Example of usage
Technical details for DREMEL® Versa (PC10-1/10)
Technical specifications
Battery voltage
3,6 V
Battery capacity
Weight
12.5 cm
Depth
13 cm
Variable Speed
2.200 1/min
Battery technology
Speed setting
Single
Precision tip
Dual temperature
Removable cord
Drip control
Delivery details: DREMEL® Versa (PC10-1/10)
Versa PC10
1x Splash Guard
3x Foam Pad
3x Non Scratch Pad
3x Heavy Duty Pad
1x Bristle Brush
USB Cable
Zipper Bag
F013PC10JA
8710364081646
8710364081646
